loaner phone problems
My loaner phone smells like smoke. I have tried tons of different things to try and get rid of the smell. I would put up with it but my room, hands, and clothes all smell like smoke. What do i do?
Photo of Courtnee
Courtnee
  • 396 Points 250 badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
Perhaps return to the store, tell them about the problem and see if you can get a different loaner phone.
Photo of Nitasha Chaudhry
Nitasha Chaudhry
  • 80 Points 75 badge 2x thumb
Try disinfecting every part of it with rubbing alcohol or place it next to some burning incense. Or do both (one after the other).
Photo of Sunny Daisy
Sunny Daisy
  • 1,178 Points 1k badge 2x thumb
I would take the battery out. Wipe the whole phone down with a cotton cloth dampened with water and vinegar. (Maybe a tsp of vinegar in a cup of water. ) a damp Q-tip for the crevices. And then wrap the phone in a cotton cloth dry. Place the wrapped phone in a container with baking soda on the bottom. Leave it over night. The cotton cloth is for protection. Just seal the phone in a container with baking soda but dont set the phone on the baking soda. Put it on something. Or lightly wrap it in a cloth.
I still say bring it back and exchange it. If you damage the phone trying to clean it you're out your $150 deposit.
Sunny Daisy
The bring it back is a better answer.
