Light Weight Plan with Small Tab?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: positive tab mention
Can I switch my plan to the $45 1GB & Unltd Min. light weight plan with a small tab. I thought I could but it wont allow me to. Wondering if its because I have another phone on the same bill with a Medium tab.
Photo of Crystal Campbell
Crystal Campbell
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
If you want one of the new plans then you'd need to pay off your existing tab, if any, and call customer service to switch to the new plans.
There's no service charge since this isn't something you can do on your own via self serve.
Note: if you're currently getting the 10% BYOD discount, it t is also not compatible with the new plans. And you'll loose it if you switch to a newer plan.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
You can't do it through self serve for now. You will have to call customer service and they will change it for you.
But if you have any negative tab , you need to pay off the Tab first.
Crystal Campbell
Ok thank you. I had switched my plan before many times using self serve but I must have had a positive tab balance then unless they changed the rules.
Photo of Mayumi
Yes, they changed the rules( tab system ) last month. And they are still working on some functions on the new self serve site.
