LGG5 gets hot when charging
  • 2
  • Updated 8 months ago
Out of the blue yesterday while charging, the area around the charging port of my LGG5 started to get extremely hot and smelled of burning, so I unplugged it.
It also didn't indicate that my phone was charging at all, despite being plugged in. I tried a different cord and USB charger and had the same issue.
I've removed the battery, my SIM card and restarted the phone - same issue.
The other baffling thing is that it doesn't do it every time I plug in my phone to charge, it's plugged in and charging right now without any problem at all.
But in the last 24 hours, it's gotten extremely hot and smells like burning 4-6 times when plugging my phone in to charge.
Any ideas what I can do?
Photo of Brian Wiebe
Brian Wiebe
  • worried.
Posted 8 months ago
  • 2
Photo of Robert
Robert, Mobile Master
  • 107,422 Points 100k badge 2x thumb
Are you using the original charger?
Brian Wiebe
Yep, using the original charger.
Photo of Dinh
Dinh, Mobile Master
  • 42,056 Points 20k badge 2x thumb
I would suggest you contact LG and ask them.
As the phone gets too hot, this is a matter of personal safety. I don't think any manufacturers would design phone to work in that conditions.
Brian Wiebe
I did contact LG and they suggested I either return the phone to them, but I wouldn't get a loaner phone. Or contact Koodo to see if I could have it repaired and get a loaner phone.
I thought I'd try here before going back to my Koodo retailer.
Photo of Dinh
Dinh, Mobile Master
I don't know if Koodo still have the policy of loaner phone, but you could try to ask the location you got phone previously.
Photo of Sagith
Sagith
  • 382 Points 250 badge 2x thumb
There must be something wrong in the hardware, you can do a free diagnostic test at fonelab.
Photo of Christian Malin
Christian Malin
  • 118 Points 100 badge 2x thumb
I can confirm that this happens more than a little bit with the G5. Ive noticed it a few times while charging, all factory accessories
