LG Optimus Can't Get Picture Messages to Work
I have an LG Optimus 1 phone with the $10 call display, voice mail and unlimited texting addon. I understand (possibly incorrectly) that this should allow me to send and receive picture messages. When I receive a picture message, I can press the download button but it does nothing. When I try to send a picture message it says "sending" but never sends. How do I get picture messaging to work?
Photo of Joshua Foley
Joshua Foley
  • 80 Points 75 badge 2x thumb
  • sad
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
Picture messages need data to be enabled to send and receive them.
It doesn't use up / charge you data though, but it needs the ports open.
However, make sure there are no background apps running waiting to automatically send/receive data and hike up your data bill when you enable data
Joshua Foley
That's annoying. Where do I go to check and disable all apps from using data?
Photo of Yannick
Yannick
Hi Joshua, here is how to disable auto-update:
1 Open Google Play Store.
2 Tap the Menu key.
3 Tap Settings.
4 Uncheck Auto-update apps.
5 Check Update over Wi-Fi only for additional security
You should also turn off data sync:
1 Tap Menu.
2 Tap Settings.
3 Tap Accounts and sync.
4 Uncheck Background data (will uncheck Auto-sync automatically).
5 Uncheck Auto-sync.
