LG Optimus Black Data Problems
I just upgraded my LG Optimus Black to the new version of Android. All seemed to work fine, but that was while hooked up to my home network. When I left home I realized that my data connection was not working. I checked out the connections, and selected the Koodo SP which got my mail to work, and the facebook app works as well. The problem is I cannot connect to anything through the browser. I simply get an error. There are a couple of other apps as well that will not connect (one from the weather network for example). Any suggestions on how to fix this?
Photo of JimV
JimV
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Hi there... Make sure the APN settings are correct...
http://koodomobile.com/en/ab/non-kood...
Photo of JimV
JimV
I checked all of them over. It seems all the settings are correct. I still have the same problem.
Photo of JimV
JimV
Solved it. I decided that even though all the entries looked correct, I would delete the current settings and re-enter them. Once I did that everything seemed to work just fine. Thanks for the help.
