LG Optimus Chat stuck in emergency call mode
  • (Edited)
My LG Optimums Chat is stuck in EMERGENCY CALLS ONLY mode, and i cant figure out how to get it out. i'm wasting money paying for the bill right now and im starting to get pissed off, ive only had it 1 year.
Photo of Tasha Dufresne
Tasha Dufresne
  • silly
Photo of Chris Petersens
Chris Petersens
You are getting pissed? :-) S_hit happens.:-) Try this. Remove battery while phone is on, take out SIM, then re-assemble and see what happens. If that fails try factory reset.
Photo of Jonathan I
Jonathan I, Mobile Master
I'm going to assume your bills are all up to date.
Please try going into Settings > Mobile Networks > Packet Data and ensuring "Use 2G networks only" is unchecked. Koodo does not use 2G networks (Only Rogers/Fido do) so having that enabled turns your phone into an Android touch screen device with no cell radio.
If that's still fine and nothing's working still, do a battery/SIM card pull as Chris suggested and update us on the situation.
Photo of shelley
shelley
  • 2,884 Points 2k badge 2x thumb
I agree with the above..
I have a LG Optimus One and experienced the same problem. I removed the battery and sim card, re-assemble. It helped. If you still have problems try the factory reset.
Photo of MSI Dhami
MSI Dhami
  • 60 Points
Nothing is working
If none of the above is working you'll need to call customer support, you may need a new sim card or the phone may have malfunctioned.
How long have you had the phone.
