LG Nexus phone frozen
I have had the Nexus 4 for about 3 weeks and it has worked fine today however I went to unlock it to use it and the screen did not open I know it does not need charging it has not been dropped the notification light is flashing but I can not open the screen to check or use it. It doesn't help that you can not remove the battery to reset the phone. Can anyone help me please
Photo of Karen McGennity
Karen McGennity
  • sad
Photo of Jeff Caughill
Jeff Caughill
  • 662 Points 500 badge 2x thumb
Do you have a Koodo shop near by? If so maybe bring it there to have them look at it.
Hope you get it working.
Jeff
Karen McGennity
Just got it working again tx for your help
Photo of Humberto Giambrone
Humberto Giambrone
  • 4,900 Points 4k badge 2x thumb
I've never had a non-removable battery phone so I don't have many suggestions. All I can think is to try plugging the USB into a computer and see if it causes something to happen. Waiting for it to die would suck.
This is my biggest fear from moving away from Samsung and getting the Nexus 5. It's ridiculous that the battery is non-removable.
Photo of Pat
Pat
  • 320 Points 250 badge 2x thumb
Usually, holding the power button for about 10 seconds reboot the phone. The phone manual has that procedure clearly explained..
Karen McGennity
Thanks Humberto will try that
Karen McGennity
Just tried still the same I will take it back to Koodo and see what they say
