LG Nexus 4 Unlocked not Finding Koodo Network
  • 2
"your sim card doesn't allow a connection to this network"
Koodo Tech support just told me to due a factory reset, then this showed up. I cannot connect to the Koodo Network
Now I've done my research online
http://forum.xda-developers.com/showt...
1 or 2 problems:
1. Broken SIM card tray
2. Lost or stolen phone has been black listed
Neither is possible, bought the phone from Google Play directly (should be brand new, should) and also, sim tray is fine.
Additionally, I try to connect automatically to the Koodo network, and only "Rogers Wireless, Telus, and Bell" show up.
Where is Koodo?
Photo of Mitch McQuoid
Mitch McQuoid
  • 240 Points 100 badge 2x thumb
  • annoyed
  • 2
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
They told you to do a factory reset right away?
*shakes head*
I apologize if you have already done these steps.
Go to Settings...
More...
Mobile Networks...
Network Operators...
Search Networks...
It will search for all available networks. From what I read before it seems the automatic connection was tried and Koodo did not come up. Sometimes when you search for networks, it might come up. If that fails, technical support can check settings on the back end of things and see what is going on. A factory reset should never be done unless it is a last resort.
Photo of Myke
Myke
Have you tried doing a manual network search?
Zaphod Beeblebrox
For piece of mind, even though it might not be the case, check the IMEI at this link.
http://koodomobile.com/en/on/switch2k...
Photo of Humberto Giambrone
Humberto Giambrone
  • 4,900 Points 4k badge 2x thumb
Is it possible it's the SIM card itself? Do you have another phone you could try the SIM in. Also, do you have another SIM you could try in your phone?
Mitch McQuoid
Tyler C, and Myke:
Thanks for your prompt reply, I did not want to do a factory reset, that's exactly what I thought, last resort, all my cached settings are there, and all obviously set back to default, big pain in the arse.
Tyler and Myke, I've tried both suggestions, unfortunately I cannot call customer support at this point because my only phone, this one, is obviously not functional.
I've tried calling with Google's free calls, but as soon as I click "6" for technical support, it says that all agents are busy and to try again later, I believe that Google free calls are not being taken "seriously" by their dialer system because they are a half-baked VOIP calling system, as such, their dialer system hangs up on me.
At this point I'll have to wait to use a real phone again, my parents should be home soon enough. But damn. This should be an easy fix.
Mitch McQuoid
My SIM tray MAY be broken, I doubt it is, I used a pointed wooden skewer to open it, but it's fine; couldn't find my SIM tool
Mitch McQuoid
@Tyler C | My IMEI number checks out
Mitch McQuoid
@Myke
Well it's probably not my SIM card, as it's a brand new Koodo Nano SIM, but I have yet to check it, remember, it was working this morning, maybe I'll try the nintendo 64 "blow it" technique, I'll clean it off and try it again.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,092 Points 100k badge 2x thumb
Nano SIM is your problem the Nexus 4 takes a Micro SIM not a Nanos SIM. The iPhone 5 is the only phone that takes a Nano SIM
Mitch McQuoid
I did say nano, but I meant micro.
Mitch McQuoid
My sim card fits the slot, would a nano fit a micro slot?
Photo of Myke
Myke
I never mentioned a sim card? lol
Mitch McQuoid
sorry Myke apparently another guy @humberto, I stand corrected
Mitch McQuoid
Now, guys, is the Nexus 4 supposed to recognize that you've inserted a SIM card at the "now insert your sim card" screen? Cause it's not being recognized, the only option is, next, and no "oh, lookie here, your sims been inserted, now you can set up wifi" on the next screen.
Photo of Myke
Myke
Turn the phone off before you insert the sim card, then turn it on. In my experience, the phone won't recognize the sim card unless the phone has been off.
Mitch McQuoid
Thanks
I guess Myke had it solved awhile ago lol
Photo of Myke
Myke
:D
Mitch McQuoid
Well I guess it says "skip" instead of next, correction. And keep in mind that this is all upon doing another factory reset.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
Did you have a koodo account before you got the nexus 4?
Did you change the sim card to a micro sim when you got the nexus 4? (Not asking if you have the right sim, just if the swap was done when you got the new phone)
Are you sure that koodo has the correct sim card number registered to your account?
Mitch McQuoid
@Timo Tuokkola, good questions
I did not have a Koodo account when I first got my Nexus 4. They set up the account at the kiosk, and gave me a new SIM card at that time.
  • 139,892 Points 100k badge 2x thumb
If you have access to self serve, I'd still recommend verifying the sim card number they have registered. (Should be under the mobile phone tab). It wouldn't be the first time the stores have mixed up the sim numbers.
Mitch McQuoid
ok great
Photo of quasarito
quasarito
Have you activated your SIM card? Also do you have the right APN settings for Koodo configured in your phone?
Mitch McQuoid
After factory reset, all the APN settings have disappeared.
Zaphod Beeblebrox
APN is generally just for data connection. It seems this device cannot connect to even the voice network.
Mitch McQuoid
hmm. well I'm at a stand still. factory reset a few times today.
Photo of quasarito
quasarito
Check your phone's network type configuration:
On the dialpad type: *#*#4636#*#*
Then go to "Phone information"...
Check under "Set preferred network type" that you have "WCDMA preferred" selected.
Also make sure that under Settings > Wireless & networks > Mobile networks that you have "Use only 2G networks" deselected (unchecked).
I mention this because Koodo does not have a 2G GSM (fallback) network, but only HSPA+ (WCDMA) / LTE
Mitch McQuoid
No dice.
Mitch McQuoid
Solution Found:
Finally got back to tech support over another phone, turned phone off > popped out SIM > popped back in > turned back on > "success"
Key here people, apparently, is too turn the phone off BEFORE popping SIM card. I think prior to solving the problem Id pulled it out with the phone being on.
Solved.
As well, intermittent data disconnections fixed too, my original reason to call in to tech support.
Thanks for all the advice guys. Much appreciated
Rachelle asked me to post her notes on the solution for her:
Turned phone off, popped out simcard for 10 seconds and then reinserted simcard. Powered phone up again and everything is working fine, even the original issue is fixed.
Photo of Ahmad
Ahmad
Unless it's an iPhone, your phone should always be off when inserting a sim card to ensure proper registration with the network.
Photo of Michael Dupuis
Michael Dupuis
  • 80 Points 75 badge 2x thumb
koodo uses telus towers and sometimes takes a while to change if at all. I had an unlocked blackberry from telus and it always said " welcome to Telus"
Photo of Myke
Myke
You're answer isn't warranted. The thread is over 4 months old with no activity.
Not to mention that it has nothing to do with the thread topic.
  • 199,264 Points 100k badge 2x thumb
And the reason your phone said welcome to Telus is because it was a TELUS phone and the software was that of Telus. what you were seeing was the splash screen which is part of the software and wouldn't change nomatter what network the phone was used on its part of the software of the phone.
