LG G2, No Mobile Data connection.
  • 5
  • Updated 2 years ago
Got an unlocked LG G2.. Calls, texts work perfectly but I can't seem to get any data on it at all.. I've tried Factory Reset and just general resets. I don't know if it's worth noting that I am a prepaid customer, I do have data and this is the fourth phone i've moved this SIM card to.. Anyone got answers?
Photo of SolidStateSR71
SolidStateSR71
  • 114 Points 100 badge 2x thumb
  • 5
Photo of Ahmad
Ahmad
You will need to update/change your APN settings
Here is how: http://help.koodomobile.com/plans-add...
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Have you setup the apn?
Name KOODO
APN sp.koodo.com
Proxy leave blank
Port leave blank
Username leave blank
Password leave blank
Server leave blank
MMSC http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy 74.49.0.18
MMS Port 80
MCC 302
MNC 220
Authentication type None
APN type leave blank
APN Protocol IPv4
APN roaming protocol IPv4
Enable/Disable APN APN enabled
Bearer Unspecified
Photo of Michael Bell
Michael Bell
  • 84 Points 75 badge 2x thumb
Thanks It Worked!
Photo of Shahzaib Awan
Shahzaib Awan
  • 80 Points 75 badge 2x thumb
I ALSO HAVE A same problem
Then try the same solution.
SolidStateSR71
Oh you beaut! Cheers mates! it worked like a charm.. I'm not very phone savy... Much much appreciated!
Photo of Lee  Chen
Lee Chen
  • 170 Points 100 badge 2x thumb
I dont know why it doesnt work for me!
I use LG G2 too , after i update apn setting there is nothing come out!!
Can someone help me?
Photo of Jason McNamee
Jason McNamee
  • 62 Points
Worked for me! Thanks!
