LG Stylo 3 Plus: Oreo
  • 2
  • Updated 8 months ago
I bought this phone from Koodo a few months ago. It came with Android 7.0 right out-of-the-box. Is there any word as to whether this phone will be getting updated to Android 8 (Oreo)? If so, when can it be expected to be pushed out? Thanks.
Photo of Marty McFly
Marty McFly
  • 1,130 Points 1k badge 2x thumb
Posted 9 months ago
  • 2
Photo of Dinh
Dinh, Mobile Master
  • 42,256 Points 20k badge 2x thumb
You would have to contact LG Canada for the update (if they are coming)
In the Android world, because your devices can run Oreo, it doesn't mean you will get the update pushing from the carrier/manufacturer. They normally prioritize hi-end devices first. Even a quick search on google saying the Stylo will never be updated to Oreo :http://www.androidoreo.info/lg-phones-to-get-android-oreo-update.html
You could root the devices and go with custom Oreo ROM but you will void the warranty.
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
It doesn’t look like it’s in the plans for future software update yet:
https://community.koodomobile.com/koo...
Photo of Dinh
Dinh, Mobile Master
  • 42,166 Points 20k badge 2x thumb
Is that telus list official and fully updated for all devices? iOS has been updated to 11.0.3 but didn't show. Ipad Air 2 update is showed as "bug fix" on Oct 11? what? lol. It should be 11.0.3
Photo of Pascal Bouillis
Pascal Bouillis
  • 80 Points 75 badge 2x thumb
Other Stylus 3 plus from other carriers already had the 8.0 update. So it's in Koodo side to make the update available...
Photo of Dinh
Dinh, Mobile Master
@Pascal Bouillis: Which carrier is it? where did you get the information on the Stylus3 plus?
Marty McFly
Absolutely ridiculous. If the phone can handle 8.0, then give it 8.0 or even higher if the phone can run it. To give it to one carrier and not the other doesn't make sense.
Photo of Dinh
Dinh, Mobile Master
None of the carrier has updated it, as far as I know.
