LG G6 usb/charging port short
  • 2
  • Updated 9 months ago
The USB-C port on the phone is shorting out the charging cord and burned my finger, bought a brand new charging cable and it happened again. Is this covered under warranty?
Photo of Ian
  • 112 Points 100 badge 2x thumb
  • hurt
Posted 9 months ago
  • 2
Photo of David
David, Mobile Master
  • 83,518 Points 50k badge 2x thumb
Unless they argue physical damage, yes it should be covered under warranty.
Photo of terry Underwood
terry Underwood
  • 132 Points 100 badge 2x thumb
hey i just got my kooodo and ive had no problms  in 2 weeks . i hope i dont.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,856 Points 100k badge 2x thumb
Had mine for over a month and had no issues what so ever, haven't heard of any other issues like this with the G6 either so hopefully it's an isolated incident Terry.
Photo of Robert
Robert, Mobile Master
  • 101,484 Points 100k badge 2x thumb
Hello Ian,
Did you use the original charging block and cable?
Photo of Ian
The original charging block and cable was used, after that shorted/melted I went to Walmart and purchased a Belkin certified USB-C to USB-A cable and the same thing happened. Customer service has informed me they will be replacing my phone.
PSA: If you smell burning electronics, the charging cable is hot and stuck in the phone, avoid touching any metal parts if you do manage to disconnect the charging cable to avoid burns.
