LG G6 Battery Drain
  • Updated 1 month ago
Question: My wife has an LG G6 that was purchased in May of 2017. Recently, the battery drain has been incredible. There are two main culprits: Google Play Services and Phone Idle. I have looked up fixes for these common issue but no luck. She was at 30% from a full charge in just over 3 hours this morning. That included less than half hour of screen on time... If a factory reset does not do the trick how do we go about exchanging it for a new one since we are still int he warranty period.
Photo of Steven Coady
Steven Coady
  • 180 Points 100 badge 2x thumb
Posted 5 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,908 Points 100k badge 2x thumb
An exchange might not do much as it was a great phone when it first came out but after updating the software I found battery life getting worse and worse which sucks because its a great phone otherwise and actually one of my favorites I've ever had. You can bring it to a Koodo kiosk and they can send it away to be looked at but I think it's LG's software being rushed while they work on Android oreo.
Photo of Todd A
Todd A
  • 60 Points
Totally agree.. I did find if u turn your screen saver off and your screen brightness down helps battery time. Plus turn your phone off at least twice a month for six hrs helps. U have to remember that battery is running 24/7. Look at it this way. If u left your car running 24/7 eventually it is going to need gas and oil plus a break. I know this sounds crazy however inanimate things need a break too
Steven Coady
Makes sense. The battery life used to be great - are you finding Google Play Services or Phone Idle a big drainer? I have no idea why phone idle would hog 20-30% of battery life...
Photo of Lloyd Willett
Lloyd Willett
  • 3,688 Points 3k badge 2x thumb
I was thinking of getting the Lgg6 do you think lg will send a software update to fix this problem in the near future thanks
  • 202,866 Points 100k badge 2x thumb
I'd probably direct your questions about battery life to LG on their socials like FB or Twitter and see if they are aware of the issue and going to address it when they update to Oreo, I just know when I first got it the standby time wasn't as bad as its gotten over the life of it after updates.
Photo of Den Fong
Den Fong
  • 90 Points 75 badge 2x thumb
I have noticed this recently on my G6 and it was shortly after a software update pushed down.
Photo of Den Fong
Den Fong
@dinh thanks going to try that, but so far the battery drain seems to be from go to the Android system
Photo of Robert
Robert, Mobile Master
  • 107,602 Points 100k badge 2x thumb
Photo of Den Fong
Den Fong
Contacted LG canada and stopped at Koodo kiosk, both recommended factory reset.
Photo of Den Fong
Den Fong
I factory reset and battery drain is gone, still a hassle though.
Photo of Dinh
Dinh, Mobile Master
  • 42,136 Points 20k badge 2x thumb
@Den: good to know, at least we knew where the problem was from.
