Lg g5 low signal
  • 2
  • Updated 1 year ago
I only get at most 3 bars of signal usually only 1 or 2. I only had this phone for 7 days and never. Had good signal, even thou i had full signal with my last phone in the same area and everyone has full signal around me
Photo of Adam Sullivan
Adam Sullivan
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 90,044 Points 50k badge 2x thumb
Some phones have better signal than others. Which phone do you have now? Do others have the same issue with the same phone? Does this happen everywhere or only certain locations?
Photo of rikkster
rikkster, Mobile Master
  • 66,966 Points 50k badge 2x thumb
A network reset may help. Go to: Settings > Backup and reset - scroll down to and tap Reset network settings and follow the prompts. Antenna design varies from one phone to the next and some phone cases, (if applicable) can sometimes attenuate or reduce the received signal.
If your not satisfied with the phones' performance, you can exchange it for another G5, go with a different brand or get a full refund. You have 15 days from the date of purchase to do this.
Adam Sullivan
I have the lg g5. It has a low signal everywhere
Photo of Goran
If what Rikkster says doesn't help you can also see if its a Sim card issue (possible) by swappijg it into another phone to see if the problem follows.
Photo of Allan
Allan, Mobile Master
  • 56,506 Points 50k badge 2x thumb
You can mess around with your settings a bit as well.
At home I get about -107db (signal strength) while using gsm/wcdma/lte. This allows me to use LTE. When i connect to gsm/wcdma auto i get a much better signal strength of -91db. This allows me to use 4G.
It could be possible that your old phone didnt support LTE and therefore only connected via wcdma in which you have a closer tower giving you a better signal.
Photo of Allan
Ah yes, thanks for the catch. I tested the speeds and it is indeed running at 3G UMTS speeds.
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
The local tower to my neighbourhood shows only 3 bars even when within a few hundred metres of it. Signal strength varies between phones, and installations.
