LG G5 android update stuck at secure start up - knock code not registering
  • 2
  • Updated 3 weeks ago
April 2017 - LG G5 android update stuck at secure start up - knock code not registering which is a big concern since this is supposed to be a screen software update.  It's still showing 30/30 attempts and there is a soft ticking sound periodically.  The screen does register the "knock" by flashing the correct square and the pattern worked yesterday so clearly the update is screwing the phone.
Can/Should I shut it off?  If so, how?
TIA
Annoyed.
Photo of Bryndis Swan
Bryndis Swan
Posted 1 year ago
  • 2
Bryndis Swan
Ok - just had to leave alone for half an hour or so and now it seems to have got past that part but I'm kind of bummed about all the bad reviews for Nougat especially the bad battery life thing.  I guess we'll see.
Photo of Cory
Cory
  • 10,482 Points 10k badge 2x thumb
Try default_password
You can thank me after. :)
Photo of Khadir Sinjari
Khadir Sinjari
  • 80 Points 75 badge 2x thumb
Sorry there are only numbers
Photo of Allan
Allan, Mobile Master
  • 54,846 Points 50k badge 2x thumb
Is it wanting a password for Secure Startup (as in the data encryption) or just a PIN number to unlock your device? What kind of device do you have? Do you see an option to reset the PIN, "forget your PIN", etc?
Photo of Philip Souza
Philip Souza
  • 60 Points
My LG Aristo did this after attempting to change my PIN. I was playing around with the settings and activated the "Secure Startup". After restarting the screen turned white and doesnt seem to respond. But if you keep tapping the screen the keypad finally appears. Whew...thought I was looking at a hard reset and losing everything.
Photo of Allan
Such a good feeling when you can fix things easier than you originally thought.
Glad you got it fixed!
Photo of Robert
Robert, Mobile Master
  • 103,584 Points 100k badge 2x thumb
Not all new updates work out of the box, this is why you'll get some updates to fix the bugs/battery issues.
