LG G4 Data not working with APN settings
  • Updated 5 months ago
Just got an unlocked LG G4 from Telus. Insert a koodo sim card and text/phone calls work fine. Data and MMS do not work however. Tried multiple different APN settings, but still no luck. Any suggestions or is the phone useless on this network?
Photo of Patrick Lenaour
Patrick Lenaour
Posted 2 years ago
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
Try these. See if this matches your settings please.
Tap the menu key.
Tap System settings.
Tap More...
Tap Mobile network.
Tap Access Point Names.
Press the Menu button
Tap New APN:
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save.
Tap the radio button at the right of the Koodo APN to activate data services.
ALso make sure your data toggle is on .
Photo of Goran
Goran, Mobile Master
  • 91,406 Points 50k badge 2x thumb
The phone is definitely compatible with Koodo so don't worry about that. If Chadwick's suggest at and confirmation of APN's won't fix it, toggle airplane mode, and if that doesn't work, pop the Sim restart th phone put it back in. Keep us posted.
Patrick Lenaour
Tried all that. Even tried another koodo sim and my sim in another phone. My sim worked fine in the other phone, other koodo sim didn't work either. Makes no sense. Could a factory reset do anything?
Photo of Chadwick
Sometimes yes. Worth a shot.
Photo of BobTheElectrician
BobTheElectrician
  • 62,064 Points 50k badge 2x thumb
But before that, try switching network type to include, then exclude LTE, and manually connecting (may take a few minutes). Then do the process with the LTE on.
Patrick Lenaour
Alright so I just backed up, factory reset, restored and everything seems to be fine. Thanks for everyone's help.
Photo of rikkster
rikkster, Mobile Master
  • 66,936 Points 50k badge 2x thumb
Have you tried resetting network settings? This is usually found under Settings > Backup and reset > Reset network settings - follow the prompts. If that doesn't work, please read on.
Make sure there are no typographical errors in this line:
MMSC: http://aliasredirect.net/proxy/koodo/mmsc (there's no space between http and ://aliasredirect. It's printed this way so that it doesn't turn into a shortened link).
Have you considered cloud storage for photos and/or music? (e.g. DropBox, Google Drive). LG offers software that allows you to backup your device, (link below). Your Google account will take care of restoring contacts and some app settings. Best to sync with your Google account before performing a factory reset.
Some app developers choose not to allow an app to be moved to SD storage as this may cause the app to perform undesirably or not at all.
http://www.lg.com/us/support/product-help/CT10000026-1438110404543-preinstall-apps
Photo of Allan
Allan, Mobile Master
  • 56,376 Points 50k badge 2x thumb
Try leaving both port and proxy fields blank and set the apn type to "default, mms" without the quotes.
Photo of Rebecca Ross
Rebecca Ross
  • 60 Points
THIS WORKED! I was trying EVERYTHING and nothing was working, then I just erased the proxy and bam it was solid! THANK YOU!
Photo of hugh trask
hugh trask
  • 80 Points 75 badge 2x thumb
likewise!   LG-G4 and Koodo prefer the "default, mms" setting
Photo of IceMan Kent
IceMan Kent
  • 142 Points 100 badge 2x thumb
I (just went through this pain).
I have an LG G4.
Apparently this phone has issues when you change the SIM card more than once.
The solution, unfortunately, is to do a Factory Reset.
This is the only thing that worked for me.
Here's a link that will help:
https://productioncommunity.publicmobile.ca/t5/Getting-Started/Unable-to-get-data-working-on-lg-g4/m-p/62064#M10093
After doing the factory reset, the phone will (automatically) set itself up with the correct APN settings.
PS - I hate that this was the only solution, but believe me, I tried (everything) else - to no avail.  If you have an LG G4, this is your only solution.  Just make sure you do the LG Backup to your SD card, and it will ease your pain (a bit).
There will still be a bunch of things to "put back" the way they were, but it is better than starting from scratch.
Good luck !
