LG G3 Power Dain
Any suggestions on how to (dramatically) increase the power duration on my LG G3? Most the time I only use it for text messages - and even then not excessive - but I seem to have to charge it every day. Thought I turned off auto-updates but don't know what to look for now. Thanks
Photo of BERNARD CHARTRAND
BERNARD CHARTRAND
  • 288 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Charging a phone every day is the norm. I know when I switched from an older phone to my GS4 I as well kept thinking that the battery never lasted long enough, but it's really just designed to last a day then needs to be charged.
To boost battery performance though just go in an turn off any feature you don't use in settings. There should also be some battery settings that allow you to see what is using up the battery. I tend to keep my phone at 50% brightness to help the battery that much more.
