LG G3 - Not receiving email / "connection is offline" message.
  • Updated 2 years ago
I have a an LG G3. For some reason, I stopped receiving email (outlook and google accounts) 2 days ago. I had turned off data because I was close to my limit, but still had access to wi-fi. I have since turned data back on - and still have access to wifi - but no updates. I know I have had emails because I see them on my laptop. When I go into email, there is a message at the bottom that "connection is offline". I don't know what this means or what to do about it. Suggestions please. Thanks
Photo of Bernard Chartrand
Bernard Chartrand
  • 166 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Have you restarted the device? That should probably fix it.
Bernard Chartrand
ok. Thanks again!
Photo of Mathieu
No problem! Habe a great day
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Matheiu, would there be a patch coming
Thank you
Photo of Mathieu
a patch for what?
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
Go ahead and go to your notification rack up top. where the Wifi/data/and location tabs are and click "SYNC" off and on again., make sure its highlighted and turned back on. This seems to fix it when it happens to my LG G3
