LG G3 group messaging issue
I bought my LG G3 after switching from iPhone 4s. love the phone but totally irritated that I can't be part f a group text. all messages in group are inividual! Any ideas? I use group texting alot.
Photo of Sabina Vaughan
Sabina Vaughan
  • 132 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,092 Points 100k badge 2x thumb
If you want to send a group message as a single text it must be sent as a picture message (mms). This means that data must be switched on. This is simply the way the text messaging system is designed, there is no way to attach multiple recipients to a single sms message. The only reason it worked on iPhone is that you were using iMessage, which is an apple specific instant messaging program.
Go into your text messaging settings and look for this option:
Sabina Vaughan
I do not have those options! Maybe programming is wrong?
I know how the iPhone works and I know android based systems can do go up as well but there isn't an option to set it up on my phone at all.
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
While in your messenger app go to settings>Advanced and the option Timo mentioned may be there.
Depends what messenger app you are using.
Sabina Vaughan
Nope got nothing. Both my husband and I are missing those options. We are using the messaging app that came with but I tried a bunch more apps. I hate when people tell me a phone works for what I want and doesn't. Can't bring phone back I think I used it too much. Now have a tab I have to deal with before I can purchase another phone. Grrrr
  • 139,892 Points 100k badge 2x thumb
Can you post a screenshot (volume down + power) of the options you DO see?
Sabina Vaughan
This is under multimedia
Photo of Jonathan I
Jonathan I, Mobile Master
Then look under Text message or Multimedia message. Android looks different across manufacturer's devices because it's modified/skinned for their design.
Photo of Spence
Spence
Sabina.    I user the Messenger app by Google Inc. from the Play store and it does have the Group messaging option you are looking for.
Try downloading it and it should meet your needs.
And the settings to get there as I mentioned above;
While in your messenger app go to settings>Advanced and the MMS Group messaging option is 1st thing on the page.
Photo of Spence
Spence
