LG 5 IMEI showing as not compatible with Koodo?
  • Updated 7 months ago
I am purchasing as used LG5 so I entered the IMEI on a Koodos site and it shows as incompatible. Why would that be? The phone is currently locked to Telus, however Telus support has said that I do not need to unlock the phone to use it on Koodo.
Thoughts?
Photo of Brenda Roche Lacey
Brenda Roche Lacey
  • 80 Points 75 badge 2x thumb
  • Confused
Posted 7 months ago
Photo of Dinh
Dinh, Mobile Master
  • 32,852 Points 20k badge 2x thumb
If it worked on Telus, it will be fine on Koodo network. The website incompatibility check was out of order, I guess.
If you need to unlock, try ebay, $2-3 will do.
Brenda Roche Lacey
Thanks.
