Less minute/more data?
  • 2
My plan is 400 minute et 1gb data . But im not using alot of minute per month . Like not even 50minute . But i use alot of data and pay extra data every month .. Is there any plan to reduce my minute and more data. All plan on the selfserve with more data have to be taken with also more minute ? :/
Photo of Simon Ouellet
Simon Ouellet
  • 182 Points 100 badge 2x thumb
  • 2
Photo of Sophia
Sophia, Mobile Master
Unfortunately not, Simon :( All the data plans come with an equivalent amount of minutes... most of us are in the same boat!
Simon Ouellet
Thank you for the fast answer! And ok that answer perfecly the question!
Photo of Dennis
Dennis, Mobile Master
  • 187,544 Points 100k badge 2x thumb
You could always try prepaid and then you can choose to only purchase data and not purchase additional minutes until you need it.
How much are you paying for the extra data right now?
Is it worth it to upgrade to the $60 plan with 2GB of data or the $75 plan with 4GB of data even if it ives you extra minutes you dont need?
Photo of Daniel Kim
Daniel Kim, Mobile Master
Also there is double data/minutes on the prepaid boosters at the moment.
Photo of Dennis
I noticed that if you use a lot of data, prepaid is actually not worth it. And it also depends on your overage rate, With my grandfathered plan the overage rate is $5/500MB. It's actually not worth it to get a current higher priced plan and the overage rate is pretty good (better than prepaid) that I consider it a pay per use rate. I pay the extra if I need it or save the money if I dont need it
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Salut Simon! Présentement, Koodo ont un plan offert pour le Québec. pour $55 tu peux avoir les textos illimités et minutes illimitées partout au pays, avec 3GB de données. C'est vraiment un bon deal, et ça t'éviterait de payer des suppléments chaque mois!
Bonne soirée!
Photo of Julie Geroudet
Julie Geroudet
  • 92 Points 75 badge 2x thumb
C'est pac cela qu'on nous dit au telephone pourtant ..
Photo of ANTOINE CARON-JOBIN
ANTOINE CARON-JOBIN
  • 132 Points 100 badge 2x thumb
Ce forfait est discontinue depuis un certain temap. Ma copine a eu la chNce de lavoir mais c mIntenant impossible. DemNdez le et on se moquera de vous Au service. Le service a la clientele et le respect du client ce sont dIlleurs enormement deteriores au cours des dernieres annes ainsi que lea forfaits qui sont mIntenant tres rigides et pas tres avantageux. Ils sont devenus comme bell : arnaqueurs et condescedants avec les clients et offrent peu de flexibilite dans leurs forfaits qui aont beaucoup plus dispendieux et rigides quavant. Cest triste car cetait la seule compagnie qui semblait honnete et a lecoute des beaoins des jeunes ce qui nest vrm plus le cas. On serr des boomers au comptoir en ignorant completement desjeunes qui attendent depuis bien plus longtemps. Je suis assez degoute de koodo, ou doisje dire Bell 2.0 ( javais quitte bell pour les memes raisons mais au moins eu ont un reseau qui capte partout contrairement a koodo qui interromp le service si lon est au sous sol...
Julie Geroudet
Je soutiens que moi même membre de koodot je paye 55$ pour 3gig de donnée ! Le reste illumiter et 10$ du Gig supplementaire j'ai ce forfait depuis 2013 ! vous êtes injustes envers votre clientèle et vous offrez un service vrqiment hostile lorsqu'on a negocier un bon forfait et que l'on vous réfères un client. C'est lq dernière dois aue je vous réfère quelqu'un
