LD rates applied to double data plan
Got the double data nationwide plan. When viewing the plan it clearly lists unlimited long distance in the plan. I still got dinged 20 bucks for long distance calls. Am I missing sonething.
Photo of Liisa Baumhauer
Liisa Baumhauer
  • confused
Photo of Jonathan I
Jonathan I, Mobile Master
The plans do include LD within Canada, but not for calls made to #s outside of Canada or while roaming. Did you make any of those types of calls? That would explain the charges.
Or... you went over on your airtime (if it's a minute bucket plan).
Could you specifiy which plan it is please?
Photo of Chris Petersens
Chris Petersens
  • 47,246 Points 20k badge 2x thumb
If you switched to a plan from a non-nationwide one mid month, long distance still applies for any call prior to the switch. Is that what happened?
