Koodo plan & Telus phone
If I have a iPhone 4s or 5 with Telus, will it work with a Koodo sim card and a Koodo plan?
Photo of Bailey Burgsma
Bailey Burgsma
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
Telus iPhones should work fine on Koodo and vice-versa.
Photo of Dennis
Dennis, Mobile Master
  • 196,478 Points 100k badge 2x thumb
After you put in your Koodo sim card you may need to plug your phone into iTunes to update the carrier settings
Photo of Ivan
Ivan, Mobile Master
I've never had to do this, but a good suggestion nonetheless if there are issues. Also, settings > general > reset > reset network settings can also be used to fix network problems (only WiFi passwords are lost, the rest of the personal data stays on the phone).
