Koodo and Vonage home phone problem.
Hi I have a iPhone 5 and 3GS. The problem is when I call any Vonage phone number, I do not get a ringback tone and I can not leave a VoiceMail. This problem occurs only between Koodo and Vonage, I tried multitude of different brands and Cell. providers with no problems?
Anybody has a good idea what this could be because I am stumped.
Photo of Jean-Luc Navert
Jean-Luc Navert
  • 80 Points 75 badge 2x thumb
Photo of -
  • 730 Points 500 badge 2x thumb
I have some ideas. I'm not very familiar with Vonage but I know it is a VOIP service.
The number you dial for Vonage, have you tried putting a 1 before dialing the number. I found that sometimes it does make a difference since VOIP isn't recognized as a landline but rather a floating line without a location. So it may count as a long distance number within North America. In this case we use the prefix 1 before dialing.
Try it and let me know. :D
Jean-Luc Navert
Hi Andrew, thanks for the response.
I tried with the 1 and no change, I get no ringback tone and no voice mail. I tried with a Bell Mobility phone and no problems!!!
Photo of Yannick
Yannick
Hi Jean-Luc, I suggest that you contact our technical support so we can look into it. We can be reached at *611 from your cell or 1-866-995-6636 from a landline, then select option #6. Thank you!
