Koodo thinks I am roaming. I am not.
  • Updated 8 months ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 611 mentions
I live ocean side in Canada. I can see the US from where I am. A tree was removed between my home and the ocean/US yesterday and now I can not use my phone because it thinks I am in the US and therefore roaming. What can I do to fix this asap?
Photo of Martine Skillen
Martine Skillen
  • frustrated
Posted 8 months ago
Photo of Goran
Goran, Mobile Master
  • 96,970 Points 50k badge 2x thumb
Go into your network selection menu and oh WHP? Wow uhmm this is a tough one. It might have to be a backend change. You can send a private message to Koodo via Facebook Messenger or DM via Twitter or 611 first thing in the morning to see what can be done.
Martine Skillen
Thank you...yup, I think I'll have to contact Koodo. Erg.
Photo of Allan
Allan, Mobile Master
  • 62,070 Points 50k badge 2x thumb
Wait. Is it prepaid or WHP.
If it's not the WHP then you can manually select Koodo in your cell phone settings.
Martine Skillen
Thanks. Can you break down this process for me please.
Photo of David
David, Mobile Master
What phone are you using? If we have that piece of information, we can better help you.
Martine Skillen
It's an LG K4. Anything else that would help? Thanks!
Photo of David
Usually you go to Settings > Carrier (or Network) and switch off Automatic. A list should populate, from which you can choose Koodo. This will allow your phone to only connect to the Koodo network. You will need to turn this off if you travel.
Note, you may have to reset this if you turn off your phone. Check it out to see.
See this link: https://community.koodomobile.com/koodo/topics/getting-close-to-the-border-and-being-charged-for-roa...
or this one: https://community.koodomobile.com/koodo/topics/i-live-near-the-border?topic-reply-list%5Bsettings%5D...
 for suggestions.
Photo of David
Can y ou move the device to the side of your home away from the tree, and see what happens?
Martine Skillen
Thanks. This works but only for a couple of texts.
