Koodo Prepaid Base Plan Expired
  • Updated 5 months ago
So my base plan expired for a couple of days. I was wondering if there's a method to fetch text messages sent to me during this period?
Photo of Christopher Cheng
Christopher Cheng
  • 152 Points 100 badge 2x thumb
Posted 5 months ago
Photo of Allan
Allan, Mobile Master
  • 62,050 Points 50k badge 2x thumb
The only way would be reactivating your base plan fast enough to receive the texts waiting to be sent to you afaik.
Photo of BobTheElectrician
BobTheElectrician
  • 67,162 Points 50k badge 2x thumb
From what I've read here, messages are held for about 4 days before they expire for good as undeliverable.
Christopher Cheng
So I topped up my base plan but I still didn't receive the text messages sent during the days my base plan was expired.
Is there any method to retrieve the held messages?
Photo of Allan
  • 61,490 Points 50k badge 2x thumb
If you aren't receiving them then you're out of luck.
I'd suggest setting up pre-autorized payments so you dont have to deal with this in the future
BobTheElectrician
  • 66,696 Points 50k badge 2x thumb
It might help to re-boot the phone to refresh your connection. Send yourself a text to flush whatever's in your queue. Whatever you don't receive is then probably gone for good.
