Koodo plan: my phone couldnt send or recieve phone calls and texts. Is there a way i can be warned if this happens again?
  • Updated 1 year ago
  • (Edited)
Koodo plan just started 5 days ago: my phone couldnt send or recieve phone calls and texts. Is there a way i can be warned if this happens again? So i dont miss something important and so people can get ahold of me if needed. I have a lg k4 (2017)
Photo of Haley Bruhm
Haley Bruhm
  • 80 Points 75 badge 2x thumb
  • frustrated.
Posted 1 year ago
Photo of David
David, Mobile Master
  • 93,614 Points 50k badge 2x thumb
Since there is no way Koodo can know if your phone ceases to work, there is no way to pre-emptively warn you of this condition.
If connectivity is extremely important for you, you should have a backup plan in place to cover such contingencies.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,524 Points 100k badge 2x thumb
Hi Haley, Did you fix the issue and are now able to send and receive texts or did you need help with that?
If you did fix the issue what caused or rectified the issue for you?
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
Hello Haley,
Did this happen when you ported your number form another carier?
Haley Bruhm
No i had gotten a new number. Ive only had it less then a week. And i just had gotten a new phone about a month ago
Photo of Sophia
Sophia, Mobile Master
Is it sorted for you now?
