Koodo not reseting my phone usage
I pay for a monthly phone service, (500mb and 500 minutes), and the quality is fine, however, it doesn't reset monthly. It's been a few months, and I would call in later, but my usages aren't changing.
Photo of Eric
Eric
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Justin Robichaud
Justin Robichaud
  • 5,002 Points 5k badge 2x thumb
Are you looking at the usage in the phone itself? Like in the settings?
For some reason, the iPhone doesn't show "actual" monthly usage.
For example: I've had my phone about a year now it says I have 7.9 gb of usage in the "Current Period"
Silly right!?
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
Or are you talking about Usages on Self serve?
Photo of Eric
Eric
Oh, my. I guess that's why I'm a noob! I was looking at the phone usage. I thought the "Current Period" meant my month, or my usage for that month!
Photo of Eric
Eric
Well, thanks for the solution, I suppose!
Photo of RudyW
RudyW
So what does current period mean then? Is it from the beginning of time until one resets it?
Justin Robichaud
On the phone? Ive actually never tried resetting it but I'm sure it's possible.
Photo of David
David, Mobile Master
  • 89,270 Points 50k badge 2x thumb
At the bottom of the Settings > Cellular page is the option to 'Reset Statistics'. This will reset your periodic usage to zero. I reset this before travelling out of the country, so I can keep an eye on my usage whether I go a day, week or more. You could also reset it each month if you wish. I use far less data than my plan allows most months and I don't worry about resetting it.
Photo of Moonmack
Moonmack
  • 4,000 Points 4k badge 2x thumb
I reset my plan once a month on the evening before the plan rolls over. I like to have my own measure of how much data I use. I've found Koodo pretty fair as their numbers usually line up with what I have. With Telus they like to use the 1000 vs 1024 so I end up loosing almost 350MB a month compared to the advertised limit. Well, I guess I'll call that a.win towards Koodo.
