koodo home phone
  • Updated 2 months ago
with the koodo home phone service if the internet is down or the power does out does the phone still work?
Photo of Nancy
Posted 2 months ago
Photo of Robert
Robert, Mobile Master
  • 101,020 Points 100k badge 2x thumb
Hello Nancy,
WHP doesn't work with wifi but with carrier signal so if internet goes down, it should work. As for the power, I don't know. I think the WHP has a battery that would mean it would still work but not 100% sure about that.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,572 Points 100k badge 2x thumb
The home phone uses the same connection as your cellphone so in the odd instance the cellular service goes down then yes the home phone unit wouldn't get a connection.
The home phone unit has battery backup so it's good for 12 hours or so without ac power
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 136,982 Points 100k badge 2x thumb
Keep in mind, though, that cordless phones won't work without power even though the home phone base unit will. You'll need an old fashioned corded phone to use it during a power outage.
Photo of David
David, Mobile Master
  • 83,270 Points 50k badge 2x thumb
Annnnnd.... there were some units shipped without a battery because the factory was short, and shipped the device anyway. Check to be sure your unit has a battery installed.
