Kitkat 4.4 is out on Nexus 4
  • 2
I just did the update. It went flawlessly. A few minor changes in the settings menu, but otherwise, it went well.
Photo of Myke
Myke
  • 2
Photo of Daniel Kim
Daniel Kim, Mobile Master
N4 owners will be happy :D
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
It's been out for about 4 days now. You should install the Google Experience launcher, it makes 4.4 awesome. The Apk file is easy to find just Google it and it will come right up if you haven't yet?. and turn on developer settings then turn on ART instead of Dalvik it makes app crashes a thing of the past, I have only had one app crash twice when I first started it after switching the ART then never again.
Photo of Jonathan I
Jonathan I, Mobile Master
How does ART do for opening apps, multitasking, and battery life?
Photo of Myke
Myke
I'm sticking with Go Launcher. I like my Diablo 3 theme :D
Photo of Marc Bourgon
Marc Bourgon
How do you get the update??
Go to your settings - About Phone - software update - check for update. Make sure to update on a full battery while plugged in and on wifi if possible as its a 300+mb file.
Also 4.4.3 is actually out now so you have 2 updates
Marc Bourgon
I did so .. several tiimes .. says i am up to date ..
