Kitcat upgrade for Samsung S3
Is there an upgrade to Kitkat for the Samsung Galaxy S3? If I'm still using 4.0.4. Can I do a direct upgrade or do I have to upgrade to 4.1, 4.2 and 4.3 first?
Thanks.
Photo of CanuckWheels
CanuckWheels
  • 112 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi there, KitKat is indeed available on the Galaxy S3. You can update your phone by following the steps below:
1 From the Home screen, select Menu.
2 Select Settings.
3 Select About device.
4 Select Software update.
5 Select Update.
6 Select OK.
7 Select Download.
8 Select Install.
It's always better to backup your phone first :) Thank you!
________________________
