Keep account / plan active, port number out?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: positive tab mention
I have a Koodo Account that I'd like to keep active, but transfer the number associated with the account to a different provider. Is this possible?
Photo of Caleb
Caleb
  • 392 Points 250 badge 2x thumb
Photo of Caleb
Caleb
My gut feeling is no... it's not, but just in case.
Photo of Rocky Balboa
Rocky Balboa
Yes you can. Make sure your Koodo account stays active. Contact your new provider and give them the account # and pin # for your Koodo account. Once this is done your account at Koodo will automatically suspend and cancel at the end of your billing cycle. Any tab balance that is left will be billed on the final bill.
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Rocky, make sure to read carefully before replying ;) Thank you for your help, it's appreciated!
________________________
Photo of Caleb
Caleb
Interesting. I was under the assumption that porting was sort of a 'final cancellation' notice to your old carrier. That once you ported, the account couldn't be saved.
But you are saying that within the finial billing period (within 30 days notice?) I can simply re-activate the account with a new number, keeping my plan, positive tab-credit, etc?
Rocky Balboa
You got it by porting out is exactly like a cancellation with your older provider. So you can only have #1 per 1 cell phone carrier. Depending when your billing cycle ends that's when the cancellation will take effect. As for your plan you lose that since you're going elsewhere, you lose the postive tab credit unfortinately.
Photo of Caleb
Caleb
But I want to keep my service with Koodo active... I don't want to cancel. I just want to take my NUMBER elsewhere, but keep my plan/service active with Koodo, I'd happily take a new number on my account.
I don't want to cancel. I just want to take the number.
Photo of Jonathan I
Jonathan I, Mobile Master
Not possible. Phone # follows the account its tied to.
What you can do, then, is add a line to your account and then port out your first #.
Photo of Caleb
Caleb
Right. I thought so. The phone # is also tied to the plan (and tab credit) as well. I could only activate a new 'in-market' plan with a new number. Cheers, thanks.
Photo of Caleb
Caleb
If the number is tied to the account and they can't be separated, then so be it - I answered my own question in my first reply, as I thought this was the case.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
So you want to port your number to a different provider. Also you want to keep your plan /account with Koodo stay active.
You can't do it unfortunately. Your account will be canceled automatically as soon as you porting number is done.
Photo of Mayumi
The request doesn't cancel your account right away. But you won't have an account with your service provider as soon as your number was ported out, right?
Rocky Balboa
The account suspends with the initial provider then cancels out end of the billing cycle. Porting cell phone #'s only take 2-3 hours.
Photo of Mayumi
Ahh, Suspends service then cancel... I get it.
Thanks Rocky :)
Rocky Balboa
You're welcome everyday is a learning experience on the Koodo forum maybe you can lecture me a bit on cell phones sometimes. I'm lacked for tech knowledge.
Photo of Mayumi
lol. I'm learning about cellphone a lot on the Koodo forum too. :)
Rocky Balboa
Ok so keep your Koodo account active. As per previous post, you can only have 1 # per cell phone carrier. So you'll have to activate a 2nd line getting assigned a completely different telephone #.
Photo of Caleb
Caleb
Thanks Mayumi - that's exactly what I thought.
Photo of Mayumi
  • 112,684 Points 100k badge 2x thumb
You mentioned that you have a positive tab. How much tab do you have?
You could use that tab to purchase a new phone and move to a different service too.
Photo of Caleb
Caleb
I've got about $95 to play with. Might pick-up a Moto G on the cheap.
Photo of Mayumi
Moto G is a great phone for the price. :)
Photo of Dave
Dave
  • 7,814 Points 5k badge 2x thumb
If you want your account active with Koodo but have your current number active with another provider, then I believe that what you should do is create another line on your koodo account - then you call the other provider that you want your current number with and have them port over the number
So that you do not get double billed (or double billed that much) the best thing to do would be to wait until near the end of your billing cycle - please keep in mind that it usually takes up to 2.5 hours to port a number from cell to cell - BUT sometimes there are issues in the port so you would want to speak with the porting department to make sure that it does go through the same day that you want it to.
