Keep the same plan with a new phone
  • Updated 1 year ago
I want to get the LG G5 with a Tab Medium and it says online that plans start from $40/month. When I asked an employee at a Koodo shop, he said I could keep my current plan ($34/month) and still get the Tab Medium. However, I read that in order to upgrade to a new phone with Tab Medium, I need an eligible plan with Tab Medium (http://help.koodomobile.com/getting-started-with-koodo/the-tab-what-it-is-and-how-it-works/Can-I-keep-my-plan-when-I-upgrade-my-phone). What is the definite answer, is it possible to keep my current plan with a Tab Medium, or would I need to change my plan?
Thanks!
Photo of Emily
Emily
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
You would need a new plan for Tab Medium, you can keep your plan with Tab Small or if you buy the phone outright.
Currently Tab Small and Tab Medium will end up equalling the same amount after 2 years, ($360).
$10×24=$240+$120=$360
S15×24=$360
Photo of Dennis
Dennis, Mobile Master
  • 187,758 Points 100k badge 2x thumb
Did your plan qualify for Tab Medium in the past?
Photo of Emily
Emily
I'm not sure what you mean, but I never had a plan of $40+. I used to have a tab a long time ago, before they changed the policy and I already paid off my current phone, I haven't gotten a new phone since so it's been almost 4 years now.
Photo of Dennis
I believe that 4 years ago there was only 1 type of tab.  Which means your plan would only qualify for Tab Small
