Keep number switch from Virgin to Koodo prepaid
One new unlocked iPhone s6, one very basic Nokia, want to keep existing numbers currently using Virgin and switch to Koodo PrePaid. Is this possible? Thanks in advance.
Photo of jean
jean
  • 134 Points 100 badge 2x thumb
Posted 3 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 61,868 Points 50k badge 2x thumb
TheĀ  magic word is "unlocked"; doing that for an iPhone can cost $$$.
AFAIK, Koodo has only one number per pre-paid account. Porting is relatively easy. Do the Nokia first, and check it out. Sign up for auto top-up and save 10% on base-plan renewals.
If you are happy after a week or so, then do the iPhone as a second account.
Photo of jean
jean
Thanks! Our usage is extremely peak/valley so glad prepaid xfr would be possible. The iPhone is a gift, brand new, no SIM card, from Apple Store so I assume it's unlocked! I want the low cost pre paid so that when we're in UK for months, I can keep our CDN # for minimal cost while using our (very much cheaper) UK #s. We aren't wealthy so we live frugally both here and there.
BobTheElectrician
While you are overseas, you only have to maintain your account every 89 days to preserve your talk & data banks. They evaporate after 90 days of your baseplan not being topped up.
Photo of jean
jean
I figure a credit card auto top up of the bare text plan would work, or?
Photo of Greggor58
Greggor58
  • 566 Points 500 badge 2x thumb
I just unlocked an Iphone 6 that was Bell Mobility dedicated over the weekend...it cost me $56...I would imagine a Virgin Iphone would be the same$
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,976 Points 10k badge 2x thumb
Yep 50 plus tax 56.50
And yes you can do the bare text plan to preserve the account.
