kakaotalk problem !
  • Updated 2 years ago
i've just downloaded kakao and whenever i write my number and press "done" says it can't connect to the server, what should I do? (I've already checked my number and it's correct)
Photo of Amanda Fonseca
Amanda Fonseca
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Is your data on our is wifi connected?
Amanda Fonseca
Yes it is
Uninstall the app and restart your phone
Re install the app and try again
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
In KakaoTalk's app review section, many users are complaining that as of the last update on August 25, 2015, the app crashes or doesn't work at all. I don't see the problem you're having mentioned, but it could stem from this recent update. You could try uninstalling and re-installing the app to see if that makes any difference.
Edit: didn't see Chad's post till I finished mine.
https://play.google.com/store/apps/de...
Photo of Julia Gamusaran
Julia Gamusaran
  • 90 Points 75 badge 2x thumb
My kakao
