Just changed my plan for data and my data isn't working
  • 3
  • Updated 2 years ago
What the title said. I've recently changed my plan to the $30/mo plan that gives you 100MB data. Soon as I have changed it I checked it to see if it's working but it's not.
Can someone please help me out?
Photo of Joel Ramlakhan
Joel Ramlakhan
  • 170 Points 100 badge 2x thumb
  • frustrated
Posted 2 years ago
  • 3
Photo of Goran
Goran, Mobile Master
  • 97,552 Points 50k badge 2x thumb
Check that data is turned on on your phone
Toggle airplane mode
Restart the phone
Take the Sim out for a minute an put it back in
Check out self-serve to see if the data block MMS add-on is in your account.
If after all of that you still have nothing then it's likely the data block is on koodo's end. Call times are really long right now so I'd suggest going to the email us section o contact us or a private message to Koodo facebook/twitter.
Joel Ramlakhan
I just reset my network settings what do I now
Photo of Goran
Does it work now or is it still just safari?
Joel Ramlakhan
Doesn't work for any app
Photo of Robert
Robert, Mobile Master
  • 107,362 Points 100k badge 2x thumb
You should go in Settings > Cellular to see if the.data is activated for all the applications
Joel Ramlakhan
I did and I switched on use of cellular data for safari but when i shut off my wifi and try to go on to see if it works, the data doesnt work
Hi Joel,
Do you have an Android or iPhone or what?
Joel Ramlakhan
iPhone
Photo of Robert
I think he has an iPhone
Joel Ramlakhan
Yes, I own an iPhone.
Photo of BobTheElectrician
BobTheElectrician
  • 67,538 Points 50k badge 2x thumb
Settings> Cellular> Cellular Data Network
Check the APN values:
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Joel! Are you still unable to use data on your iPhone?
Joel Ramlakhan
Yes I am still unable to use data on my iPhone.
Photo of S. Sargent
S. Sargent
  • 60 Points
I am having the same problem on my Android.
Photo of Daniel
Daniel, Employee
Since we can't access your account here to see what might be causing this, can you send us a private message on our Official Facebook or Twitter pages?
Joel Ramlakhan
ill do that
Joel Ramlakhan
I've just sent them an authentication form and waiting for a response.
Photo of Rory Clark
Rory Clark
  • 62 Points
literally the exact same thing is happening to me on my account execpt i have 1 GB of data
Photo of Alicia Tymstra
Alicia Tymstra
me too! when i first got my moto g two years ago, i asked the rep to disable my data since at the time i didn't have it as part of my plan and didn't want to accidentally use it. So now that I just got a new plan with data, i'm trying to figure out how to get it to work.
Alicia Tymstra
i totally just got data so i can play pokemon go haha :P
Alicia, you need to call Koodo and have that block removed. Then you can hunt seagullasaur or bandicoot
Photo of Mathieu
Mathieu, Mobile Master
I thought the data block was capable of being removed through self serve?
Joel Ramlakhan
Back to my case. Should I go to my local koodo store to get assistance?
BobTheElectrician
Joel, store will just bounce you back to *611 which is overloaded. Save yourself a trip.
Give the Facebook folks a little time to get you going, and let us know how long it takes so that other customers will have a guideline.
