I've text to 4545 "10 tnt" for U.S. coverage but ...HELP
  • 3
I've text to 4545 "10 tnt" for U.S. coverage but I'm not getting confirmation, as I usually do. I'm leaving in 2 hours! I re-text ( worried about double billing) but I need the coverage....
Photo of Sabina Lavictoire
Sabina Lavictoire
  • 132 Points 100 badge 2x thumb
  • stressed
Posted 3 years ago
  • 3
Photo of Jonathan I
Jonathan I, Mobile Master
Make sure it's in caps and not separated. I believe it's case sensitive like that.
Otherwise if it's not working, you could try adding it via self serve on your computer.
Photo of LairdC
LairdC
  • 5,164 Points 5k badge 2x thumb
Make sure your spelling is correct. It's not "tnt" but "10txt" you should be texting.
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Hi there...
Log into your Self Serve app, go to plans and add-ons... Check if the roaming pack is already there, if not you can add it from there... Once it is provisioned in your account you should see it there... Once provisioned, It should be under Manage Add-ons.
Enjoy your trip!!!
