It takes 8 hours to charge my neo S5 even with the new battery, what is wrong?
  • Updated 2 years ago
Photo of Fred E Santos
Fred E Santos
  • 184 Points 100 badge 2x thumb
  • frustrated
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
Are you using the OEM charger?  Is fast charge enabled?
Fred E Santos
Hi , where can i find and enable the fast charge?
Photo of Dennis
  • 196,080 Points 100k badge 2x thumb
If your phone has that feature it is in Settings>Battery>Fast Cable Charging
Fred E Santos
It does have a battery feature on the settings but no Fast Cable Charging feature.
Photo of Robert
Robert, Mobile Master
  • 106,876 Points 100k badge 2x thumb
There's not fast-charge on the S5 Neo unfortunately, but 8 hours is way too much
Photo of Goran
Goran, Mobile Master
  • 97,688 Points 50k badge 2x thumb
Hmm, that is a very long time. Does it take several hours regardless of the charger you use? Can you try other chargers? Do you have other devices tot est the charger you're using on?
Fred E Santos
Yes , i tried other chargers but the same result.
Photo of Robert
Here's how to see what battery uses most your battery : http://www.samsung.com/ca/support/skp/faq/1098165
Photo of Robert
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
I had this issue with my s7edge. I had to totally drain the battery before charging and this resolved the issue completely.
Photo of Chadwick
Fred E Santos
thanks for the advice..
Photo of Andrew
Andrew
  • 1,392 Points 1k badge 2x thumb
Sometimes this can be caused by issues with the phones changing port if it's malfunctioning or pocket lint got inside. Take a close your at your charging port and see if you can see anything (if so you can carefully use a small pin and clear it).
Photo of rikkster
rikkster, Mobile Master
  • 68,314 Points 50k badge 2x thumb
A computer duster (compressed air) would be a safer option. Never use metallic objects to clear debris from the charging port.
Photo of Andrew
Andrew
Rikkster is right, the compressed air will be a better option. Also when saying pin I was thinking of a tooth pick and not an actual pin did not intend for any confusion.
Photo of rikkster
Had the same issue with a friends' older S4. Drain the battery and allow it to charge fully without turning the device on. An image of a battery with a lightning bolt and charging percentage will appear on screen for 4 or 5 seconds. You may not see the battery image at first because the battery may not have enough of a charge to display it. Be patient, it should appear after 5 to 10 minutes of charging.
The battery image doesn't stay 'on'. To periodically check the progress of the charge, press the power button for a half second to display the battery image.
Fred E Santos
Hi, did it fix the problem or that remedy worked? Thanks.
