Issues with Samsung Galaxy S2X
  • 3
I've been having a growing number of issues with my Samsung Galaxy S2 X.
Calls: I can call people, but they often can't hear me and just hang up, or it echoes to the point where they can't hear me very well.
Apps: Music Player keeps restarting from the very beginning of my music every time I open it, regardless of the fact that I was in the middle of a completely different song, the apps often crash for no reason, and the message notification icon will not go away.
Photo of Jill Young
Jill Young
  • 90 Points 75 badge 2x thumb
  • upset
  • 3
if you're getting a lot of app cashes and forced close errors chances are you need to restore the phone to factory using recovery
make sure you backup or sync your contacts and other important info before you begin.
turn the phone of and remove the battery then put it back in
hold both volume key and the power button. when you see the galaxy splash screen let go of the power key
use the menu to perform a data wipe / reset
if you still have issues you may want to call tech support
Photo of Brian Norton
Brian Norton
  • 1,146 Points 1k badge 2x thumb
Try to install Samsung Cares app.Has some self diagnosis info. https://play.google.com/store/apps/de...
one day i just took a photo by my Sumsung S2 X suddenly got struck , then it's vibrating but display is not appeared
i gave it to repair but he told its not a software problem related to hardware
don't know what to do
he asks a specification to open it and repair
please help me some one to fix this
i want to know what is the cause of this problem
Photo of Victoria Henriquez
Victoria Henriquez
  • 60 Points
I had the same situation right now. What happened with your phone, did they fix it?
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Victoria,
What were you doing on your phone when you started getting these issues? If you provide some details as to what happened then we may be able to get a solution figured out to be able to help you.
Photo of Diane Bertram
Diane Bertram
  • 60 Points
Twice in the past week, I have had the same problem with my phone freezing when I was taking a photo (which did not save at all). I was not able to do anything at all with the phone as it was completely stuck, but I managed to turn it off anyway. When I turned it back on, it seemed ok though. Why does it do this?
Photo of rikkster
rikkster, Mobile Master
  • 66,986 Points 50k badge 2x thumb
Do you have a microSD card installed? If not, all your photos are being stored in the phones' internal storage area and it may be nearing full capacity. Usually, you'll get a message or a warning icon in the notification area of low storage space. In some cases, the S2x won't take the photo at all until the low storage problem is resolved. If you do have a microSD card installed, by default all photos taken are stored on the microSD card.
