Is This Going To Be A Problem?!?
Last year in October I sent my phone in to get the scroll on my Blackberry fixed. I received a loaner phone and have been using it since. Am I ever going to get my fixed phone back? and if I don't is this going to be a problem if I want to get a new one?
Photo of Christa Kunka
Christa Kunka
  • 170 Points 100 badge 2x thumb
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Chances are, what you had done was a priority replacement which means Koodo sends you a phone to use permanently. You would not receive your phone back. Tog et a new phone, the Tab would be a good thing to look at and that may be enough to help with the purchase of a new phone.
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
Your phone has been getting fixed for 10 months? I'd call Koodo and see what's going on with that. Usually the way the Blackberry RMA process works is you send your device in to them and they give you a new-refurbished one as a replacement.
Zaphod Beeblebrox
Pretty sure, based on her explanaition, it was the priority replacement
Christa Kunka
Ok Thanks guys! good to know there will not be any problems =)
