Is there a way for me to get more data added to my plan
I need more data
Photo of Jenny Callsen
Jenny Callsen
Photo of Al Robidoux
Al Robidoux
  • 1,262 Points 1k badge 2x thumb
Depends on your rate plan. If you are on any of the Canada Wide Data plans that are listed on the site, then you are charged an extra $5 for going over your allotted data by 50 to 250 mb in a given month. If you are on one of the tab large plans, then you are charged an extra $10 for each 500mb of data that you use over your allotment.
Take for instance my plan. I pay 75.00 for unlimited minutes/text and 1GB of data. If I happen to go over my allotted data in the month, then I am charged an extra $10.00 for each chunk of 500MB.
Or if you are on the 64.00 Canada Wide Data Plan, you have unlimited minutes/text and up to 1GB of data. If you happen to go over your data allowance, then you are charged an extra $5.00 for each chunk of 250MB that you use.
