Is there a charge for texting when I go to USA, other provinces or Europe?
Photo of Jon Broadbent
Jon Broadbent
Photo of Jonathan I
Jonathan I, Mobile Master
If you're texting FROM Canada, no worries! Your texts are international, but you will need the proper international code found here:
http://help.koodomobile.com/plans-add...
If you're LEAVING Canada to use your phone in those places, then you will be charged...
1. US: $1.50/minute, $0.60/text
2. Europe: same rates
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
Voice and data rates can vary depending on where you're roaming. SMS rates are consistently $0.60/msg.
Photo of Jonathan I
From what I can see on the travelling section on the website, Europe is classified as "Zone 1" and thus incurs the same roaming charges as the U.S.
Photo of PZABOY
PZABOY
  • 5,142 Points 5k badge 2x thumb
It is free to receive text outside of Canada correct? Only to send you will be charged, sound right?
Nope, charged for sent and received while roaming.
Photo of Camilo_A
Camilo_A
  • 31,032 Points 20k badge 2x thumb
Here's the full chart for Roaming rates...
Photo of shelley
shelley
  • 2,884 Points 2k badge 2x thumb
If I'm sending a text from my phone in Canada to a Cdn friend visiting the USA, it's free? And I need to use an international code? I looked on the above link but didn't see any code for USA?
No charge to you as long as you're in canada. There may be a charge for them, though. No country code needed since it is a canadian number. The US is part of the north american numbering plan, so no country code is required anyway.
Photo of shelley
shelley
Thank you Timo!
