Is texting faster on LTE?
I've noticed it takes only a second to send a text on LTE while it takes 3 seconds or more on HSPA. Is that true?
Also, why does my phone randomly go out of service for few seconds or so? It seems to do that when it's changing towers or when I turn on wifi after it was off. Is it a network issue or a phone issue? I've had the same problem with Virgin prepaid.
Photo of Eric Kim
Eric Kim
  • 414 Points 250 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,938 Points 100k badge 2x thumb
Only when sending MMS (picture messages) because it sends those over your data connection. Texts that just contain text no it doesn't send faster on LTE.
So basically the only thing it speeds up is data transfer or things that use the Internet such as your browser, Facebook, Email, etc.
Keep in mind that LTE drains your battery about 35% faster than using HSPA so in my opinion LTE isn't all its made out to be, especially if your battery isn't lasting as long as you need it to.
Photo of Eric Kim
Eric Kim
Well I've noticed that texting (not MMS) is faster on LTE... Guess it's not necessarily true then
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,766 Points 100k badge 2x thumb
If anything it's going to be marginally slower on LTE, since the phone has to switch back to HSPA before it can be sent.
Photo of Robski808
Robski808
  • 1,088 Points 1k badge 2x thumb
SMS sends over voice network - MMS and video messaging sends through data.
LTE is Data-so should not impact texts. What device is it?
Thanks I already said that. No need to repeat what has already been said in a thread. Thanks.
Photo of b cobb
b cobb
  • 82 Points 75 badge 2x thumb
I think this comment was made to clarify your post and its more to the point. The OP specifies texts, and was confused by your post.
As a new member, find it an odd response from a "mobile master".
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
What device are you using?
