Is it possible to change a phone plan?
I have a Samsung Galaxy Ace phone and I would like to change the plan. Is that possible?
Photo of Adamo Masi
Adamo Masi
  • 108 Points 100 badge 2x thumb
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
Absolutely Adamo! You can change your plan for free in self-service once per billing cycle :)
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
yes it is . You can either do it on koodo self serve for free , once per bill period, or you can call client care and they will charge $10 for the change .
Better to do it by your self ;-)
Photo of Camilo_A
  • 30,138 Points 20k badge 2x thumb
Remember that when your plan is expired, once you change it, there is no way to have it back... So check them up, and if you are ready to make your change, go for it!!! :)
Photo of e-wizard
  • 350 Points 250 badge 2x thumb
you're able to make the plan change on self serve, once per cycle, just make sure you do the change on the first day of your bill cycle to avoid proration.
