Is 1 GB data enough for what I use?????? Help please?
  • 2
I have the $60 Canada wide Data plan giving me 1 GB of data a month. On my iPhone I turned off all location serivces, all push notifications, signed out of anything that would use data (mail) and turn off my apps in the back ground. I use facebook maybe once or twice a day max just when I'm out of the house (otherwise I use wi-fi with my cellular data shut off). My question is 1GB of data enough for my usage. I don't use Youtube or download apps on my data etc. Mostly my phone is on wi-fi. I also have a data monitor app but I'm afraid its not accurate enough.
Photo of akaykay33
akaykay33
  • 1,192 Points 1k badge 2x thumb
  • slightly concerned
  • 2
Photo of Ahmad
Ahmad
Oh yes, 1GB is definitely MORE THAN enough for your described usage.
Photo of Isaac Attree
Isaac Attree
  • 90 Points 75 badge 2x thumb
Absolutely! If you only do some occasional surfing but mostly use wifi you should definitely be fine with 1GB.
Photo of akaykay33
akaykay33
Thanks so much!! :) I tend to get a little worrysome about data because my friends have told me some horror stories about over usage and charges (but they aren't on koodo)
Photo of Ahmad
Ahmad
Koodo also sends you warning texts about your usage (not also guaranteed) and you can check your usage on your self-serve and you can download the Koodo Self-serve app. Just go to the app store and download it! Then you can check your usage right from your phone!
Photo of akaykay33
akaykay33
Ok thanks. Yeah I have the app on my phone and I check it often sometimes its not right up to date but by the next day it is. Too bad those warning texts may not always be guarenteed. Thanks for your help though!!
Photo of Ahmad
Ahmad
Self-serve is only about 4-5 hours behind so your actual usage isn't too far behind.
Photo of Camilo_A
Camilo_A
  • 31,012 Points 20k badge 2x thumb
