Is Xiaomi redmi note 4 compatible?
  • Updated 1 year ago
I am planning to buy redmi note 4 but just want to verify whether this one is compatible with koodo supported frequencies. https://www.aliexpress.com/item/Original-Xiaomi-Redmi-Note-4X-Mobile-Phone-Snapdragon-625-Octa-Core-...
Photo of Yogesh Dhuria
Yogesh Dhuria
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,868 Points 50k badge 2x thumb
Yes it is. You're looking for 850/1900mhz for 3g and 1700/2100mhz or 2600mhz or 700/750/1900 for lte. The first two are most common. A good site (but not always perfect) is willmyphonework.net that'll check for compatibility with most phones in the world with most carriers.
I use the note 3 pro atm and I think that you'll like the note 4x.
Photo of Allan
Allan, Mobile Master
  • 62,896 Points 50k badge 2x thumb
You will do fine for 3G but LTE may be spotty depending on where you live as 2600 isn't available everywhere. Look at the coverage maps for Koodo. You will get LTE in the 4G LTE advanced zones but will recieve 3G otherwise. Something to take in consideration if you dont live in an LTE+ area and want LTE over 3G.
http://help.koodomobile.com/coverage-...
Yogesh Dhuria
Thanks all for the quick response. :)
