Is usage of data taking my minutes even if I'm not phoning
  • Updated 7 months ago
My phone is a 5S and I was wondering if using data, like texting and playing games on my phone without wifi takes my minutes ( I have a 100 minutes per month) even if I'm not phoning anybody????
Photo of Chloé Versfelt
Chloé Versfelt
  • 114 Points 100 badge 2x thumb
Posted 7 months ago
Photo of David
David, Mobile Master
  • 93,400 Points 50k badge 2x thumb
No. Data and minutes are completely separate buckets.
Photo of Allan
Allan, Mobile Master
  • 61,880 Points 50k badge 2x thumb
It means youve used 50% of your data. To save data you can restrict which apps can use data or just turn it off when you aren't using it.
Chloé Versfelt
How do I turn it off and how do I restrict apps from using it???
Photo of Allan
This page will tell you everything you need to know:
https://www.google.ca/amp/s/www.imore...
Chloé Versfelt
So does that mean I don't have unlimited data, and that I only have 100 minutes per month???
Photo of Allan
Koodo doesn't have unlimited data on any plan.
If you login to selfserve and click view my rate plan you can see what you have for minutes and data.
