Is there an add on for Canada wide calling?
  • Updated 2 years ago
I do not have Canada wide talk and text but will be travelling to Saskatchewan(I'm in Toronto) and need to be able to call/text. Is there an add on for this or do I have to switch my entire plan?
My plans is the $45
  • 200 Local minutes – Does not include Canada-wide anytime minutes
  • 1 GB of data
  • Unlimited messaging
Photo of Jacqueline Statten
Jacqueline Statten
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,508 Points 100k badge 2x thumb
You can get the add-on for $20 Unlimited Anytime minutes (this is canada Wide)
https://www.koodomobile.com/add-ons
Photo of BobTheElectrician
BobTheElectrician
  • 67,538 Points 50k badge 2x thumb
That's the best way to travel with belt and suspenders on. And if I'm not mistaken, the add-ons and plans are charged pro rata for the month. If you travel for only a few weeks, you can remove it and revert back to your original plan, even if that's no longer available once you're back home. You would pay only for the few weeks of use rather than the whole month.
Otherwise, following Ahmad's tip below, your bill may be a really messy surprise to reconcile, given the way "long distance" works on local call only plans.
Photo of Ahmad
Ahmad
If you don't add any add-on, just know that calls you make to numbers within that local calling area are not comsidered long distance. So if you're in Saskatoon for example, you can call another Saskatoon number and its considered local and you won't be charged long distance. If however anyone calls you, it will be long distance. Good tip to know :)
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Jacqueline!
If you don't add the $20 option, you'll be charged  50¢ for long distances.
In other words, the local calls you make while in Calgary will be using your 200 minutes but the incoming calls will be charged long distance.
Basically your local calling area follows you all over Canada for outgoing calls but not for for incoming calls.
So the amount of Long Distance you make will allow you to decide if you take the $20 Add-on or if you end up using Pay-per-use.
Hope that helps :)
