is there a way tp unlock the radio chip for no wifi or data radio use?
  • Updated 2 weeks ago
Photo of warner himsl
warner himsl
  • Annoyed
Posted 2 weeks ago
Photo of Goran
Goran, Mobile Master
  • 94,320 Points 50k badge 2x thumb
That'll depend greatly on what phone you have. If it was carrier locked or OEM locked. I'm not aware of anything you can actually do. Have you tried something like next radio to see if it'll work?
Photo of Allan
Allan, Mobile Master
  • 59,616 Points 50k badge 2x thumb
If its disabled you're pretty much out of luck.
You can check a list of compatible phones here: http://nextradioapp.com/supporteddevices/
Photo of srlawren
srlawren
  • 3,752 Points 3k badge 2x thumb
I'm not even sure what the question is.  @Warner are you saying you want to prevent any mobile data or wifi usage?  Or are you saying currently you can't use either and you want to?  I'm confused.  What phone brand and model (be as specific as possible with the model number) do you have?  Does Wi-fi data currently work?  Does mobile data currently work?  Do you have mobile data included in your plan?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 141,672 Points 100k badge 2x thumb
They're saying they want to listen to FM radio without streaming it.
Photo of srlawren
srlawren
@Timo oh.  Gotcha.  I assumed radio chip meant cellular radio.  I don't think any of my phones have had an FM radio feature, so I never think of that.  Thanks for clearing that up.
