Is there a roaming charge for using "Map and Go" in the USA?
Roaming charges for navigating in the US
Photo of Mike Oliver
Mike Oliver
Photo of Dennis
Dennis, Mobile Master
  • 177,700 Points 100k badge 2x thumb
If it uses minutes or text or data then yes it will.
If you can use it offline in airplane more with only GPS on then no it won't
Photo of Daniel Kim
Daniel Kim, Mobile Master
If you are using data in order to use it then yes. If the maps are saved onto your device then no.
