is tethering possible?
using a prepaid plan with my android and sometimes using my tab or my notebook by using wlan or usb tethering.
Photo of Sigfried Hofmann
Sigfried Hofmann
Posted 3 years ago
Photo of BobTheElectrician
  • 57,028 Points 50k badge 2x thumb
It's not a function of what Koodo plan you're on as long as you have data enabled. If your phone supports it, you can use it as a mobile hot spot.
A warning though, using a phone as a hot spot for desktop or laptop computers is a good way to chew thru data very quickly. Most internet sites recognize when you are accessing from a mobile device and will send out slimmed-down versions of pages and images to save bandwidth. Not the same story at all if you access from a normally land-bound device.
My landline was down for a half day last year, and just half an hour total of brief tethering from my desktop cost 30 MB of data. Tab may do somewhat better.
  • 203,644 Points 100k badge 2x thumb
You may need to edit your apn settings to include 'dun' in the Apn Type
